CWVISA.OCX for .Net
Hi , Im currently converting an old VB6 app that uses CWVisa.ocx to C# .
Is there a new version (managed assembly if possible) to these ActiveX control that can be used by C#? Where can i download it?
When running the VB6 app , there is a message showing that the OCX is of older version , how do i update th OCX?
Thanks.
Human knowledge belongs to the world
(4,943 Views)
VISA comes with a .NET native api for developing VISA applications in C#. Examples are included for C#. If you don't have VISA you can download the latest version from here.
(4,929 Views)
As a side note, if you have Measurement Studio Professional or later, you have access to the Instrument I/O Assistant which integrates into Visual Studio as a code designer.  Its UI can be used to first create and configure instrumentation tasks and then generate the equivalent VB.NET or C# code. You can generate either VISA or GPIB calls.
Also check out the C# and Visual Basic .NET Instrument Control tutorial.
Best Regards,
Jonathan N.
(4,912 Views)
