Call Library Function in LabView 6i to access U2C_SpiReadWriteSS transfer routine used by Diolan interface adapter only returns the first byte from the SPI Slave
What version of LabVIEW are you running? I'm running 6i. When I looked for examples as per your instructions, I didn't find any named "Call DLL." Thanks again for you help, it is greatly appreciated!
Message 11 of 17
(2,325 Views)
I'm using 8.2. Sorry, forgot that you were running 6i. The example should still be available in 6i. Check the "Program Files\National Instruments\LabVIEW 6i\examples\dll\data passing" directory, or thereabouts. You can also check the Knowledgebase for "calling external code from LabVIEW". There used to be a separate document available called "Using External Code in LabVIEW" that was later integrated into the LabVIEW help. In 6i it was still separate. The 7.0 version is here. The basic premise still holds, though.
Message 12 of 17
(2,319 Views)
Hi, I'm a LabVIEW beginner and as you've been working on this library calling, I was wondering if it is possible that you send your final program online. Thx Zm@steR
Message 13 of 17
(2,195 Views)
Are you asking this of me, or the original poster? And, what specifically, are you referring to?
Message 14 of 17
(2,190 Views)
I was asking it from who can help me ^^ But I just saw that this program will not match my application because I want to communicate with the I2C protocole and not the SPI one. Perhaps you can help me thaught. Do you know what is the type of the data return by the U2C-12. e.g. I set the clock and the datasheet says : Return values: U2C_SUCCESS The I2C bus frequency value was successfully set. U2C_HARDWARE_NOT_FOUND U2C-12 device referenced by hDevice handle was not found. Do I have tu use a string ? (Hope you'll understand me, my english is quite poor)
Message 15 of 17
(2,185 Views)
Do you have the API documentation? If not you can download it from Diolan. The return value is an integer, as you can see from the figure in post#8. U2C_SUCCESS refers to the value of the enum, which is what is used in the C library. If you installed the software for the board you will find the definitions for the datatypes in the file "C:\Program Files\Diolan\U2C-12\Src\Common\i2cbridge.h".
Message 16 of 17
(2,168 Views)
Sure I download it. It's easier to work with it, but I don't understand everything. Sometimes it's quite difficult for me to understand english specs. And as I just start with LabVIEW, it's even harder to manage to find which kind of value I've got to use. I'll work on it, but I you can expect for several more questions. Thanks again for your help.
Message Edité par Zm@steR le 05-22-2008 02:49 AM
Message 17 of 17
(2,152 Views)
