Can 8 units of USB-6509 work at the same time using USB hub connected to one PC?
Dear,
       I currently using 2 units of USB-6509 and Labview 8.5 which works fine by defining two DAQ assistant in my Labview program. For the new system, we are going to use 8 units of USB-6509, will they work at the same time by connecting all of them to one PC using USB hub?
Thank you,
Best,
Message 1 of 10
(4,509 Views)
At that point, I would be more inclined to go with the PXI route.  It would be a lot more reliable.  I do not trust USB for test systems.  I have had way too many issues.
Message 2 of 10
(4,488 Views)
The answer is yes, but probably not in the manner that you are thinking.  All of the USB-6509 devices will work; however, it comes with a limitation.  These devices will not be able to work simultaneously as only one can be addressed at a time.  They will work and require some programming and a latency understanding as there is only a single USB port that gets distributed out to each hub, port, mouse, keyboard,... all share.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 3 of 10
(4,483 Views)
Thank you for your suggestion.
I checked PXI solutions, including chassis, controllers. For working with a laptop, it either needs a PCI express card or a thunderbolt 3 port. Unfortunately my laptop has none of these ports.
Message 4 of 10
(4,471 Views)
It all depends on the speed and accuracy that you need.
What are the specs?
greetings from the Netherlands
Message 5 of 10
(4,438 Views)
Dear,
       Thank you. My specs is not that strict. I need all 8 units of USB6509's Digital IO to be refreshed every 1mS. There's a while loop, within the loop, 8 "write task" is assigned to each of the USB6059. I need each iteration of the loop to be completed within 1mS. In considering connecting all of the 8 units of USB6509 in a USB hub which connects to my laptop. Each USB6509 has 96 digital IO output needs to be refreshed.
Best,
Message 6 of 10
(4,430 Views)
If you insist on sticking with USB, then get an industrial hub with plenty of power capability, including an external power supply.
Message 7 of 10
(4,404 Views)
@JiaLiGenmark wrote:
Dear,
Are you using a real-time system?  If you are dependent on a windows-based machine, your loop times will occasionally exceed your 1mS requirements.
Message 8 of 10
(4,396 Views)
Minions wrote: If you are dependent on a windows-based machine, your loop times will occasionally exceed your 1mS requirements.
From what I am quickly finding out on the web, the latency of the USB communication could be in the 1ms range.  So there are many problems with the current requirements.  I see this as another reason to go with PXI, where the latency will be in the sub-us range.
Message 9 of 10
(4,392 Views)
Dear,
Thank you. I am using windows. If it only happens occasionally, it's OK for my application.
Your first reply triggers me to order 8 of USB6509 and give a try. I will keep this post updated when I get any results.
Message 10 of 10
(4,382 Views)
