Can GPIB Analyzer intercept message ?
We know that GPIB Analyzer can capture message between controller and instrument. Is it possible to monitor one command from controller and stop forwarding to instrument?  We just want to control talker to stop sending one command to listener.
Thanks!!!
(4,436 Views)
based on pinout
https://en.wikipedia.org/wiki/IEEE-488
I think may be you can unwire connector then isolate DIOs for one direction with some thing like diodes and wire them again to connector. in this case you have just receive and no send
tools(like ) for and then
(4,400 Views)
It's a little complicated! 🙂
Can we disable NI Spy listening?  I do NOT want ni spy to sniffer communicating from my application since we try to protect our controller application.
(4,397 Views)
Even if it is possible to disable NI Spy, any other GPIB controller could be attached and put into listen only mode and 'see' the bus traffic.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(4,365 Views)
just do not respect to standard in cable and in protocol also you can use hashing method for sending data
(4,359 Views)
