Can I get Keithly 181 nanovoltmeter drive for labview
I want to get the drive suited to work in labview 5.0 version for the instruments,
1.Kiethley 181 nanovoltmeter
2.Lakeshore 91c temperature controller
If any one can help me in this regard,it will be greatly appreciated.
Libu
IIT Bombay.
(3,404 Views)
There are many instruments drivers available at the National instruments website. Just go to the link below and click on "Downloads". If the driver that you are looking for is not there, go to the link and click on "Other Driver Resources". It links you to other sites that have instrument drivers.
http://zone.ni.com/idnet/
If you find a driver that is made for an older version of LabVIEW, you may still be able to use it in LabVIEW 5.0. For LabVIEW 3.x and up, you would just need to mass compile the vi's that are a part of the driver.
Kim L.
(3,404 Views)
