Can I share one PCI-GPIB card with NIDevice and NI488.2 dynamically?
This is the followup for Reference#6462-VS2237.
The instrument is running with Win2000. There is one PCI-GPIB card on the instrument. The default usage for PCI-GPIB card is NI-Device, but if we install LabView or something, it requires PCI-GPIB card to behave like GPIB controller. The only way we can do now is to uninstall NIDevice and install NI488.2 driver (v2.0) and vice versa if I want it back to normal. I am wondering if there is any way we can dynamically switching the functionality of PCI-GPIB card as a NI-Device and NI-GPIB controller. My experience on NI488.2 version 2.0 and NIDevice 1.3 failed, but succeeded on version 1.6 and NIDevice 1.3.
What I did is to switch INF files, uninstall PCI-GPIB from Device Manager, and reboot. The PCI-GPIB always works as the GPIB controller no matter which driver is used if version 2.0 of NI488.2 is installed. After I delete nigpib.inf and nigpib.pnf files from INF folder and drop nidevice.inf to INF folder, uninstall PCI-GPIB from Device manager, and reboot, the device manager shows the correct information "NI-Device GPIB interface" and everything looks normal overthere. However, I can not talk TO the instrument from other PC or Unix station via GPIB cable at all. When I use MAX to explore the connection, I can still see GPIB0 over there which convinces me that PCI-GPIB is not associated with NI-Device even though it uses NI-Device driver.
However, if I switch the lower version (v1.6) of NI488 and the same version of NIDevice (v1.3) with the same procedure. It works just fine as seen from the following evidences:
. I can talk to instrument via GPIB cable if I switch to NIDevice mode;
. I can not see GPIB0 interface from MAX if I switch to NIDevice mode;
. I can see GPIB0 interface from MAX if I switch to NI488 mode;
. I can not talk to the instrument if I switch to NI488 mode.
I am working for Tektronix. This is very important and urgent to us. If you have any solution, please let us know. I would appreciate your help very much.
zhongsheng
(3,416 Views)
Try using the NI-488.2 1.7 driver. This driver is based on the older driver version and it is still the lastest driver for some platforms.
DiegoF.
National Instruments.
(3,416 Views)
Thanks, but it is still possible that somebody installs NI488.2 v2.0 and disable NIDevice on the instrument. Since the combination of NI488.2 v2.0 and NIDevice 1.3 is not good choice for us, I am thinking that I can stick on NI488.2 1.6 or 1.7 and NIDevice 1.3 and prevent the future installation of NI488.2 on the scope. If I want to manipulate the registry key of version 1.7, what would be the best key I can change so that NI488.2 v2.0 GPIB driver will not be installed automatically. Rightnow, there are CurrentVersion, MajorVersion, and MinorVersion. Thanks.
(3,416 Views)
