Can I use Labview to communicate with GE FANUC 90-30 with 331 cpu?
Am using Labview 9. PLC has serial communication only.
Have searched the knowledgebase but still don't know where to start.
The only modules I have in addition to Labview are FPGA and RealTime.
Don't know what to put on block diagram first.
(3,374 Views)
Hello
I recommend starting with the Basic Serial Write and Read example.  You can find this in LabVIEW by click Help>>Find Examples, then search for Serial.  You should find a list of commands your PLC will respond to in the documentation you got with it.  This example should show you the basic VIs used to communicate over serial.
Cheers,
(3,349 Views)
