Can I use the driver 8720B/C (HP) to control and communicate with my HP8720D?
1. I would like to find drivers for HP8720D and HP8722ES. Please help.
2. If I add more options on 8720D or 8722ES, for example change 2-port to 4-port, the existing drivers are still applicable?
(3,287 Views)
This is a question best answered by Agilent. If the instruments share the same command sets, then you can use the same driver for both. All you have to do then is turn off the ID query. You can also contact Agilent to see if they have a LabVIEW driver for their instrument. If they do not, you may want to hire an Alliance Member to write an driver for you.
Alliance Member Directory
http://www.ni.com/alliance/alliance_member.htm
(3,287 Views)
