Can I write a program that utilitzes the GPIB Analyzer (not using MAX software)?
I would like to use the Anaylzers functionality to 'monitor' what data and commands the controller is sending over the bus. I would like this to be a standalone application that does not require NI-MAX and anayler software to be open. Are there gpib commands that the analyzer can use to do this? Thanks for any help.
(3,332 Views)
Hi C,
There is no API available for the Analyzer functionality. There isn't any plans to implement this feature.
If you have a use case that you would like to share with the R&D group, you can email the technical support group. This does not mean that the feature will be implemente, but it helps us keep track for what features there is demand.
DiegoF
National Instrument
(3,331 Views)
