11-26-2014 01:54 AM
just want to evaluate LabView, but get only errors.
Do installation, works, searched & installed drivers, Agilent 34401 or Agilent 33120A, the classics I think, abd open an example ==> error.
Whats wrong?
Can't buy a expensive software which doesnt work, sorry.
With best regards
Gerhard
11-26-2014
02:01 AM
- last edited on
10-19-2026
03:46 PM
by
Content Cleaner
11-26-2014 02:06 AM
Hi Kees,
I installed the LabView evaluation package. Whats VISA? I see 'Product Line GPIB', ok, had an GBIP interface, very old, but I want to connect my stuff via USB (serial), so is VISA the right stuff?
With best regards
Gerhard
11-26-2014 02:36 AM
11-26-2014 02:51 AM
.. ok, thanks, so the discription is little bit missleading.
I know, thar serial over USB isn't a Ferarri, so just want to do some first steps to evaluate what the software can do for us ...
Thanks a lot, will try soon, just waiting for dowmload ..
With best regards
Gerhard
11-26-2014 03:43 AM
.. sorry, but installing VISA didn't change so much, see error message.
But now my GWINSTEK desktop power supply (GPD-3303S) appears in 'Connected Devices', so something has changed, but still no sample of 33401 0r 33120A working.
With best regards
Gerhard
11-26-2014 04:39 AM
11-26-2014 06:55 AM
found the VISA Interactive Control and send IDN commands here the results:
Agilent 33120A works.
Agilent 54641D and Agilent 34401A fails. But, when I send a TST command, than the instruments starting their self tests.
Fazit: The RS232 interfaces were connected correctly (no Tx connected to Tx problems, wrong baud rate, parity ...) but I can't receive messages from the 34401A and 54641D for what reason ever. I start playing around trying different settings (1 or 2 stop bits, flow control variants, termination char ...) but can't find a solution. I also restart the PC.
Any ideas?
And LabView still not working, can't run any sample, so I can't try the 33120A sample, which potentially has a chance to run ...
With best regards
Gerhard
11-26-2014 08:21 AM
11-26-2014 08:22 AM
