Can a ISA GPIB work in labview7.0 or 8.0??
We have a AX5488 GPIB card, it can work in labview4.0,
but now,we have installed the 7.0, and it doesn't work.
how can i do?
thanks
Message 1 of 8
(4,270 Views)
See the following pages, which describe the latest NI-488.2M drivers.  If your GPIB adapter is found in the list, it means the latest driver supports your h/w, allowing to use the latest LabVIEW with it.
For NT platforms the latest is 2.4.
For 9X platforms the latest is 2.2.
Message 2 of 8
(4,263 Views)
Oops, your GPIB was not an NI-GPIB...
Better to contact the GPIB board manufacturer about if they provide Win32 GPIB driver DLL that is suitable for your Windows version.  If they do it, you will be able to use the latest LabVIEW with it.  Best if they provide LabVIEW VI libraries.
According to the following site, they do not claim LabVIEW compatibility and Win98/Me/NT/2k/XP support though.
http://www.axiomtek.com.tw/product_detail.php?model_num=AX5488&majorcat=Data+Acquisition+%26+Control...
Message 3 of 8
(4,260 Views)
I have got the Win32 GPIB driver DLL,and have the driver for labview4.0 ,and it works well.
My Question is if I can use it in labview7.0 or higher version?
Message 4 of 8
(4,251 Views)
As you already have Win32 DLL for the GPIB board, basically you can use LabVIEW 7 or 8 with it. This is because Win32 version of LabVIEW are able to call *ANY* Win32 DLLs.
If you already have VI (LLB) wrapper for the DLL provided for old LabVIEW, basically newer LabVIEW versions can convert it.  However I am not sure that LabVIEW 7 or 8 can directly convert from LabVIEW 4 VI format.
Message 5 of 8
(4,237 Views)
Where can I find the VI (LLB) wrapper ? It is generated by the C/C++?
thanks
Message 6 of 8
(4,231 Views)
And If I have the llb, how will I do?
Message 7 of 8
(4,228 Views)
Normally wrapper VI functions or thier collection (LLB) module for a DLL are provided by the DLL's provider or by yourself.  Without wrapper VIs, you just call a DLL function through the Call Library feature of LabVIEW (Function Palette -> Advanced -> Call Library Function node).  Because direct DLL calls from LabVIEW are very troublesome coding and require function prototype knowledge, wrapper VI functions that wrap the low-level DLL calls are prefered.  VIs or LLBs are written with LabVIEW, not with C++.
Message 8 of 8
(4,219 Views)
