Can i interface SR510 through 32-bit PCI/IEEE488.2 card using Labview software?
I've never used the instrument but make sure that you are initiating a measurement with each iteration. And by continuous run, I hope you're using a while loop and not the Run Continuous button on the toolbar. Don't use that except for special debug operations.
Can you post the code you've written for doing a continuous acquisition?
Message 11 of 11
(980 Views)
