Can't communicate with Sorensen XG series through USB
hi Dennis, it is Daniel again.
in MAX it does show up as a new COM port, but it seems VISA has difficulty to access it.
"Error:(Hex 0xBFFF0072) The resource is valid, but VISA cannot currently access it. "
Message 21 of 27
(2,654 Views)
You've mentioned two different errors. The last one you mention usually happens when you have another program, such as hyperterminal open.
Message 22 of 27
(2,649 Views)
hi Dennis,
"the last one" is the only error i have now. Although i can see the port (COM3) working properly in VISA Interactive window, i am still getting "The resource is valid, but VISA cannot currently access it " ...... Desperate...
Message 23 of 27
(2,644 Views)
The image you posted does not show an error. If you are actually trying to run LabVIEW at the same time, close MAX. As I said, the error occurs when you have more than one program trying to access the same port. A search of the forum for that error code would have told you the same thing.
Message 24 of 27
(2,640 Views)
Hi Dennis,
i just get the stupid COM working, after closing MAX as you said. Thank you soooooooooooooo much Heart
Message 25 of 27
(2,635 Views)
I had trouble using the Ametek USB driver.  It worked for 1 power supply starting with address 1.  I had four power supplies.  I found that when I addressed all as 1 and put them on a powered USB hub they all responded.  The interface still runs slow (1284 ms).  The ethernet interface worked faster (500 ms) but was unreliable.  Also had to address all 31 for ethernet.
Message 26 of 27
(2,318 Views)
Hi Wire,
I would like to recommend you to create another thread explaining this issue, because this one have been inactive for almost three years. This way you will probably be receiving more answers and suggestions from our team
Jonathan Rodriguez
Message 27 of 27
(2,271 Views)
