Can't connect Osciloscope via USB
Hi, Im noob with Labview, Im trying to connect Lecroy Waverunner serie 6000 via USB but NI Device Monitor isn't detecting it. Im using last version with NI-VISA/488.2/DAQmx and this driver http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=07C0AC709BD14C10E0440003BA7CCD... Its the base default driver for all Waverunner scope.
Im trying to get the VISA name via Labview with the object of the driver but is imposible to me. If someone can give some advice or guide, I will be very grateful.
Im getting this errors:
-Error -1073807346 occurred at Property Node (arg 1) in LeCroy Wave Series.lvlib:Write.vi->LeCroy Wave Series.lvlib:Screen Capture.vi->Untitled 1
-VISA: (Hex 0xBFFF000E) The given session or object reference is invalid.
(1,194 Views)
It isn't a NI device, so there is no reason NI Device Monitor should detect it.  However, it should show up in MAX (Measurement and Automation Explorer) as a raw USB VISA device or as a COM port (I have not used a Lecroy Waverunner, so I am not certain which).
GCentral
(1,169 Views)
Ok thanks, that is nice information, however it dont appear in MAX, so I need try to see it as RAW or COM. I dont know how to do that, but thanks a lot.
(1,156 Views)
