Can't reach a remote divice cRIO
Hello everybody,
I am not very practical with this forum so I will relaunch my issue, as I didn't receive any reply. If I am not using this forum in rong way I will appreciate any suggestion in that way even.
I have a cRIO9022 on my LAN which I can connect to with the MAX application installed on my PC. That works fine.
I have to place the cRIO in a remote location which I can reach from my LAN through the Internet, by means of a WiFi modem-router in the remote location, connected to the cRIO.ng to reach
Now I cannot anymore connect to the cRIO9022.
My doubts:
1) Is there any guided procedure to establish the connection from MAX to the remote cRIO?
2) Do I have to set any particular rules regarding the rules of the remote router-modem? I have tried to do port forwarding but I do not know what ports MAX SW is using to reach the cRIO.
Thanks to everyone that can give me a hint with this issue, even partially!
Nice day,
G
(1,407 Views)
The difference is that within the same subnet everything works fine but something goes wrong outside the subnet. I don't know enough to guide you but that is the problem.
greetings from the Netherlands
(1,386 Views)
Many thanks you for answering Albert.
What is the problem is very clear for me. What is not, instead, is how to solve it or at list find the begining of the road...
G
(1,376 Views)
