Can't run executable build with 6.0.2, missing library?
missing library is HP6633B power supply, however when I select library, window pop-up states that I cannot select existing library. Does not allow me to go any further.
(3,425 Views)
The reason for this is because your target machine is missing some needed Shared Libraries. You will simply need to copy the appropriate Shared Libraries from your development machine to your target machine before you load the executable.
Zvezdana S.
(3,425 Views)
