Can't use VISA resource Error (Hex 0xBFFF009E), but can see instrument/query in NI MAX
As the title states, I have no problem seeing the instrument in NI MAX (instrument is an SR830 lockin). I have 488.2 installed for using GPIB-USB and VISA 16.0 is also installed. However, if I run any labview vi using VISA resource, it comes with the error HEX 0xBFFF009E, VISA or a code library required by VISA could not be located. However, I have removed and reinstalled VISA 16.0 several times. I've checked if there are any issues with hardware using another computer with a working version of Labview+VISA and have had no issues reading the device as setup. The only difference I can tell is the nonworking one is Windows 10 and the working comp is Windows 7. Still, they have the same installs, and I can see everything in NI MAX with both computers. Any help would be greatly appreciated.
(3,714 Views)
Could you attach the communication image from NI-Max along with your vi that shows where you are trying to elicit the same response from your instrument?  (Pictures or code are worth 1K words)
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,692 Views)
