Can you regulate clear sweeps using Lecroy Wavesurfer 454?
I was wondering if anyone knew of a way to regulate the clear sweeps function of the Lecroy wavesurfer 454 using Labview 8.0.  Thank you!
(3,272 Views)
Matchur,
Is this a feature that you are able to control on your wavesurfer as a stand alone device? There are quite a few different configuration VIs that can modify many of the settings, but I did not find  any explicitly for clear sweeps. Could you give me more details of  what you  have  tried so far?
-Marshall R
(3,252 Views)
