Cannot see my instrument in NI-VISA config, Red Hat 5, USB connection.. HELP
Did you reboot the system ? Just blacklisting doesn't unload an allready loaded module.
Another option would be to move away the module from the location where it is loaded from ( probably somewhere under /lib/modules/<your running kernel version>. But this is only a workaround, since every kernel update will bring back the module. In that case you might ask on a Red Hat specific support channel for the right way to blacklist the module.
Message 11 of 28
(3,717 Views)
I swear i rebooted the system... i'll try it again when i go back in after the weekend. Thank you so much for your help! I hope this is the issue i've been having the whole time and that once i blacklist usbtmc, it will work.
Message 12 of 28
(3,710 Views)
Hi DavidLoganProgrammer,
Is VISA the only NI product in the equation? Keysight has their own VISA drivers. We don't support it, but it might be worth a shot.
Message 13 of 28
(3,663 Views)
Hey Jeff,
Yeah, Keysight doesn't support VISA drivers for linux really, they refer me to http://www.tamsinc.com/sicl/ .. The drivers are pretty pricey so I just wanted to see if the NI VISA drivers worked on my red hat system because that would be a free solution for automating the VNA.
David
Message 14 of 28
(3,646 Views)
Hi David,
What environment are you progamming in?
Message 15 of 28
(3,621 Views)
Red hat enterprise linux 5
Message 16 of 28
(3,616 Views)
Hi David,
What I meant was: What language are you programming in (C, C#, C++, etc)?
Message 17 of 28
(3,610 Views)
Hey Jeff,
Python. Using the PyVisa library, which is a wrapper for the visa i/o library.
Message 18 of 28
(3,596 Views)
Hi David,
Thanks for clarifying. Unfortunately we don't support Python, so while some customers are able to get desired functionality using Python, I don't specifically know why. I wish there was more support I could provide for you. Hopefully another forum user will chime in for you.
Message 19 of 28
(3,593 Views)
Hey Jeff,
I feel that the choice to use Python is quite arbitrary in this case, since it is just a wrapper for the NI VISA library. The NI Visa configuration utility doesn't even see the usb device connected, so I don't think i'd have any better luck with a C/C++ program.
Message 20 of 28
(3,587 Views)
