Gagi, thank you so much for your prompt response.
I use your thought 1), and can capture the waveform with some delay. For one of my two purposes, that delay (~ 1 sec) is irrelevant. For my second one, that is really inconvenient. I will try 2) and 3) to see what happens.
Regarding your question, actually I do not want to measure a DC signal. For my first purpose, I need to analyze a signal like this:
and each cycle (||||----) lasts around one hour. Since I cannot capture a one-hour waveform, I am trying to capture parts of that waveform every 3 seconds, for example, so at the end of the hour I could analyze those 20 captured waveforms. As it can seen, at some times I need to capture 0 volt signals, and I need to use a 'scope.
Tha
nks again for any help.
