CentOS 7.3: gpibexplorer not running
Because of installation problems in the last CentOS 7 version, I gave CentOS 7.3 a try. CentOS 7.3 is older than GPIB 488.2 drivers (17.0.0f0 is from 05.04.2017).
Now installation was working, kernel modules have been installed. Even the device was visible:
[root@ERBUSZE bin]# lsni
Scanning localhost for devices...
System Configuration API resources found:
GPIB0
[root@ERBUSZE bin]# lsni64
GPIB0
ERBUSZE
But still gpibexplorer is not working:
Can't load library /usr/local/lib/liblvrt.so.15.0
libGL.so.1: cannot open shared object file: No such file or directory
To download the LabVIEW Runtime engine, go to http://www.ni.com/rteFinder?dest=lvrte&version=15.0&platform=Linux&lang=en
Installation of libGL.so.1 fails:
[root@ERBUSZE bin]# yum install libGL.so.1
Transaction check error:
file /boot/efi/EFI/centos from install of fwupdate-efi-12-5.el7.centos.x86_64 conflicts with file from package grub2-efi-1:2.02-0.44.el7.centos.x86_64
file /usr/share/dbus-1/services/org.freedesktop.PackageKit.service from install of gnome-software-3.28.2-3.el7.x86_64 conflicts with file from package gnome-packagekit-common-3.14.3-7.el7.x86_64
Message 1 of 1
(2,388 Views)
