Change device symbolic name on GPIB-ENET
Using a GPIB-ENET/100 interface under MacOS X, I want to communicate with an old device that requires a specific symbolic name. There is no device confuguration utility with NI488.2 package. So how does one change the device name from the default one?
(3,244 Views)
Please clarify what you mean by the device requiring a specific symbolic name. The device should only need a primary/secondary address. Are you perhaps referring to the device's software requiring a device template? (i.e. Device template: The driver associates the name "foo" with an instrument at address 2 that requires EOI and no EOS characters. The software calls an ibfind on the name foo to obtain an instrument handle.) National instruments suggests dynamically creating a handle with the ibdev function instead, this is better for portability to different computers and different OS's. So if your application uses device templates, I suggest just modifying the code to use ibdev instead of the ibfind. If this is not possible, let me know.
Ray K
National I
nstruments
(3,244 Views)
