Chart Y Offsets ?
Is there a way I can code a chart to have different Y offsets for each channel using one of the chart properties?  Currently I add an offset to the data before wiring it to the chart.
John?
(3,446 Views)
That is the best way to do it.
X modifications are easier because there is only one x start value and an increment.
But addig an offset to an array is a simple operation in LV
greetings from the Netherlands
(3,445 Views)
