Choice of laptop
Hello all,
I am looking for a laptop to perform data acquisition activities. I found out that processor speed mostly defines the speed of execution of code. So I looked for some laptops, and now I am facing a choice: Is an i7 processor with 16 GB  worth the difference in price above an i5 with 8 GB ?
I will use standard NI hardware and software.
And does is matter if I use a 64 bit laptop? I read that some labVIEW toolkits are not compatible with 64 bit.
Kind regards,
San
(2,865 Views)
For simple DAQ programs, the better processor will gain you very little.  For heavy processing and analysis, go with the better processor.
Just stick with the 64-bit OS.  32-bit apps will still run on it.
(2,854 Views)
Thanks 🙂
(2,832 Views)
