Communicate modem using visa
Hi all
I have a problem to communicate with PCI modem using VISA
When I tried to communicate with the modem using Hyper Terminal there was no any problem
but when trying to write to modem an AT command using LabView error -1073807298 occurred
I already checked the baud rate, flow control Parity bit, stop bits , Data bits and the termination character
The PCI modem is :US Robotics modem- product: USR64-802884-02
 SW: LabView 2009 Visa 4.6.2
Guy
Message 1 of 9
(5,840 Views)
But did you also enable the termination character for send?
greetings from the Netherlands
Message 2 of 9
(5,821 Views)
I disabled the termination character and sent 0x0d in the text string
its work with another modem I have problems only with the US robotics modem
thanks for response
Guy
Message 3 of 9
(5,810 Views)
As far as I know the usrobotics needs CrLf so add these characters
in decimal 13, 10 or in LabVIEW /code /r/n
Message 4 of 9
(5,784 Views)
Hi
I tried also 10 13 as termination character with no luck
I think the problem is not what I send but How I send the data
With other modems if the termination character is wrong there is no response from modem
With the US robotics modem there is an error massage
Regards
Guy
Message 5 of 9
(5,773 Views)
I'm sorry I did not check the errornumber.
This error means an IOerror, probably already on the write, so I guess that you still had the serial port open by another program like hyperterminal or MAX
Message 6 of 9
(5,767 Views)
This error occurred even after restart the computer
as I wrote before with other modem everything good and also with the same modem with Hyper Terminal
but when I'm try to use the US robotics modem with labveiw this error happens
I don't think this is a HW issue because this modem works well with another SW
Guy
Message 7 of 9
(5,758 Views)
So it must be a software problem.
Can you post your vi that has this problem?
Message 8 of 9
(5,753 Views)
see the following link
This suggest not using the VISA Configure Serial Port.vi but setup the VISA property nodes to set each property separately
Regards
Ray Farmer
Message 9 of 9
(5,751 Views)
