Communicate with Stepper Motor (MBC-12101 Driver)
I am looking to communicate with an Anaheim Automation 23Y306D-LW8 stepper motor using Labview to input a variable velocity time trace. The system is currently set up using MBC-12101 driver and PCL601XCE controller. I'm having trouble communicating with the motor using Labview, but have been successful using the Anaheim Automation SMC60WIN program. Any sample code/advice would be greatly appreciated.
(1,232 Views)
You may get an answer from the forum members if they used the same device and developed something that is sharable, but the best place to ask "Any sample code/advice would be greatly appreciated" would be the manufacturer or supplier of the device.
Since you're a new member, just to clarify, LabVIEW is just another programming language, so, in order to control your device, the device manufacturer must specify how to control it from A programming language, without that information, unfortunately, none of us will be able to help you.
Santhosh
Soliton Technologies
(1,221 Views)
Hi emb721,
Echoing the comment above, the best approach would to ask Anaheim to see if they have a programming guide for the PCL601XCE controller.  From its website, it looks like it has RS-232/RS-485 ports for communication, so you can check with them how to use LabVIEW to communicate with it.
If this approach doesn't work, you can also replace the PCL601XCE with a LabVIEW-compatible motion controller.  Your MBC-12101 driver is pretty standard, there is a product called GECO Motion that can directly control the MBC-12101 from LabVIEW.  Check this out: https://geco-lv.com/geco-motion-getting-started.html.  Just connect the wires from MBC-12101 to GECO Motion and you'll be set to go.
(1,189 Views)
