Communicating over a GPIB connection in C++
To Communicate with a device in C++ over a GPIB connection. how do you install necessary files to get                #include "decl-32.h? header file to work?
(3,763 Views)
(3,754 Views)
I found this as a location to find the file
  • Older versions of the drivers installed the files in the  partion in the following directory \Program Files\National Instruments\NI-488.2\Languages\Microsoft C
  • Newer versions of the drivers (post Vista support) install the files in the \Documents and Settings\All Users\Documents\National Instruments\NI-488.2\Languages\Microsoft C
    But when i try to go there i cant get all the way to that directory there are missing folders
    I am using M S visual studio 6.0    2005
    (3,733 Views)
    Please keep the discussion in one place so people can follow and see all of the comments. This is to help you as much as it helps us. Thank you.
    (3,724 Views)
