Communication ISO-Tech IPS-3303
Hello together,
i know there a some similar topics. I read these threads already and many other stuff belong this topic. But the communication does not work anyway.
The Power Supply is connected over USB to the PC, there is a USB-Serial Converter inside the Power Supply i guess.
I can control and read values of the dievice with the VISA-Testpanel without any Problems.
If i took the same parameters and commands in LabView to the "simple serial communicaton.vi"-VI, nothing does work. .
When i tried to write, there is no error und no change on the device. If I try to read there is a Time Out Error.
I don't know how to find out what the problem is (i'm a LabView Beginner), can you help me to get this work?
Thanks a lot
Greetings
Johannes
(1,493 Views)
Hi
Did you add an endcharacter?
LabVIEW doe not add it.
greetings from the Netherlands
(1,489 Views)
Hello Albert,
yes i did add a end character.
(1,470 Views)
