Communication by RS232, I would like to know which charater (%c) is for the escape touch ?
Hi everybody,
 I'm actualy facing a communication problem between Labview 7.0 and a weight controler (Sartorius Signum 1).
 In the hyper terminal all is working well but with the same configuration on Labview is not working at all, I guess the problem is that I don't know what is going out of a string cste, I mean which type ASCII or something else. And I would like to know which character define "ESC" I already try in Hexa and ASCII, respectively 1B and 27 but it doesn't work.
Here it is, if anyone knows I beg you to share the information ^^.
Regards.
(3,224 Views)
Put your string control or constant in Hex mode and use 1B
(3,218 Views)
