Communication problems with Prodigit PD3311D eletronic load
I am trying to communicate with the load using RS-232 serial port and the instrument drivers supplied by the vendor. I am using a "getting started" example, but i still cannot read from the load. This is probably a newbie problem, but still I'm lost.
I get error code -1073807339, what does this mean?
(3,536 Views)
If you right click on the error indicator, you can select 'Explain Error'.
The timeout error means that there was nothing read from the instrument - probably because it did receive a correctly formatted command. Verify your com port settings and that you are using the correct type of serial cable. Try testing the connection with Hyperterminal.
(3,532 Views)
