Communication via GPIB with HP54120B
In my theses I handle with a HP54120B and on old PC with GPIB interface. The problem is that when I ask the instrument the waveform (":wav:data?") and it writes on the buffer a string of binary numbers. The problem is that I have no idea on how transform it on the information I want (I tried to directly transform it into the decimal base but without success).
I also have problems on getting the numbers from the buffer. I'm able to pick up just the first one.
(4,038 Views)
Agilents manual list for that scope includes  a  "Programmer's guide for Quick C and Quick Basic" .  This manual includes some example code for transfering data from the scope to a PC . You will find that manual at http://cp.literature.agilent.com/litweb/pdf/5090-4457.pdf
(4,019 Views)
Thank you Markus
But I think you didn't undestand my question. I already read the programming manual (from the bottom to the top) and I know the instructions on how to tranfer data from the instrument to the PC. My problem is that the data I receive is in binary and I don't know how to convert it.
Furthermore I wasn't able to pick all the numbers from the buffer, just the first one.
(4,012 Views)
Thank you Markus
(4,011 Views)
The data format is described at page 53 of that manual and there is a sample how to convert the data to volt/time pairs on the following pages
(4,009 Views)
Problem solved
Thank you very much
(3,996 Views)
