Communication w/ UTM Shimadzu AG-100kN X plus
      Hello everyone, I'm trying to set up a communication with a UTM Shimadzu AG-X plus of 100 kN, in order to remotely be able to acquire data of the standard tests (Forces & Positions) in real-time and to control the start & stop test triggers through LabVIEW. The general idea intended to follow is represented on the link below:
http://www.shimadzu.com.br/analitica/produtos/test/estaticas/servo-eletricas/labview.shtml
     However, Shimadzu does not provide the proper drivers to execute what's intended. Is there any other appropriated option  (communication protocols, developing own drivers, GPIB) that someone suggests performing this task?
Thank you for your attention.
Message 1 of 1
(1,240 Views)
