Communication with HP4194
I am having a problem communicating with the HP4194A. I get an time out error when I Querry *IDN?. The HP4194 uses HPIB.
Is there something I can do to get it to recognize it?
(3,784 Views)
If you are using a National Instruments GPIB board, then you should have a program called the Interactive Control on your computer (ibic.exe) that comes with the driver.
Open ibic (it looks like a dos window) and run the commands that are listed on our web site at:
http://www.ni.com/support/gpib/max/ibic.htm
If the ibln command says your device is listening, then it may just be that the device doesn't respond to the *IDN? command, but rather to some other type of identification command.
(3,784 Views)
The HP4194A should respond to a IDN? query, not *IDN?.
bbeal@morganelectroceramics.com
(3,784 Views)
