Communication with LPM01A power consumption measurement board
ST offers a power consumption measurement board which can measure very small current: 1nA .. 200mA
X-NUCLEO-LPM01A:  https://www.st.com/en/evaluation-tools/x-nucleo-lpm01a.html
My Question: Is there a LabView driver for this board? Has anybody implemented the communication in LabView or heard about?
(It needs communication over USB VCP (Virtual COM Port) with 3,6MBit/s.
It can be used stand-alone but can also be used as an instrument, controlled by commads.
Document about communication with the board:
https://www.st.com/resource/en/user_manual/dm00418905-getting-started-with-powershield-firmware-stmi...
Implementations with the board:
Python implementation script:
https://github.com/JerryShen1995/Power-Monitor
Python and C implementation of tests:
https://github.com/mjosaarinen/pqps
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
(2,073 Views)
Hello Eugene,
I have read all the tables, datasheets and documentations for the X-NUCLEO-LPM01A but found nothing about LabVIEW. I even requested information from Digi-Key Electronics (they also sell this board), but they were also unable to answer about connecting using LabVIEW. 😐
(1,941 Views)
Hello Mr. Genius,
in LabView you simply open Serial Port which is from the board
with these Parameters:
Serial COM port configuration of USB-VCP (main interface):
– Baud rate: 3.6 Mbit/sec (3686400 bauds)(a)
– Data: 8 bit
– Stop: 1 bit
– Parity: none
– Flow control: none
And send the commands as written in
e.g. "volt 3300m" as written on page 22
BR
E.Wiebe
Eugen Wiebe
Bernstein AG
(1,937 Views)
