CompactRIO
Hallo,
I have a special device that communicates with computer by USB after installing USB to UART driver. It means working with virtual comm port. Now this device will work with CompactRIO. Is there anyone know how can I  install the USB to UART drive in CompactRIO? Or somebody has some idea about this.
Thanks!
(3,277 Views)
can you use serial port to communicate with this device? if so, you may consider through NI 9870 or 9871 module.
https://www.ni.com/en-us/shop/model/ni-9871.html
(3,256 Views)
