Compare address on the VME-GPIB
The GPIB-1014 had an option to set the VME compare address via P2 to the backplane. Does the VME-GPIB have the same option. Per the KnowledgeBase, the VME-GPIB references the GPIB-1014 User Manual to define the pin-out of P2 with the additional IEEE-488 interface pins defined.
(3,211 Views)
These signals are not routed on the VME-GPIB, and the P2 pins are no connects. The ability to set the base address is available from the onboard DIP switch only. The KnowledgeBase that was posted at the time was incorrect and has been removed. We apologize for the confusion. You may use the VME-GPIB Installation Guide to set the base address: http://digital.ni.com/manuals.nsf/webAdvsearch/91D94345006DEB9286256CE00004ED82?OpenDocument&vid=niwc&node=132100_US
(3,211 Views)
