Compatibility of PCI-GPIB IEEE 488.2
We currently have an instrument connected to a computer running windows XP via a GPIB connection to a PCI (GPIB-PCI IEEE 488.2). As it is one of the older models, I am wondering if it is compatible with newer windows OS's? I had a look at the driver section for this GPIB PCI, but couldn't find a newer one than the one for Win2000/XP.  Does anyone have an idea? We'd like to switch our ancient computer to a newer one which would run Win8/10.
Kind regards,
Steven
(5,786 Views)
Thank you for posting this question. I would like to check up on this post since no one in the community has gotten back to you yet. Regarding the available drivers - you are looking in the correct place, and the most recent one available for Windows is indeed for XP. So if you want to use the same hardware with a newer PC, Windows might not be the best option.
However, note that newer driver versions are available for Linux. Considering this, you can either upgrade to a newer PC with Linux, or get a newer Windows PC with a Windows XP virtual machine on it (which gets quite cumbersome to use according to the customers I have spoken to).
Sara N H
(5,740 Views)
Accepted by topic author StevenVanuytsel
I've had no issues with Win7 and older model PCI GPIB cards that I transfered from old Win2k and WinXP machines.  In fact I find them more reliable than USB-GPIB due to new Windows power management features that often disable USB ports without notice.
Install the NI-488 drivers first, put the cards in the machine and see if they are recognized and install the driver ok.  Then check NI-MAX to make sure they are visible.  If both of those steps work then you are off and running.
Craig
(5,734 Views)
Hi again,
After consulting with one of my colleagues, I found this:
The most recent driver supporting the PCI-GPIB is NI-488.2 17.6, and it is supported on Windows including 10/8.1/7 SP1. There is a web download link here: http://www.ni.com/download/ni-488.2/7272/en/
Hope this is helpful to you.
Best,
Sara
(5,665 Views)
Thanks for your help. I installed the 488.2 drivers, together with NI-VISA, something which was suggested by someone at NI. I am not sure if it would work with only the 488.2 drivers, but everything is up and running now.
(5,652 Views)
