Computer cannot run Polymorphic VI
I am trying to bring up my VI on my laptop, but it will not run due to Poly VI not being executable.  My desktop has no problem.  Both are running labview 8.2, any suggestions?
(3,573 Views)
On the computer having issues create a new VI and place an instance of the  polymorphic vi on the block diagram. Right click on the polyvi and select "open polymorphic vi". This will show you which vi is broken, you can then open it and debug.
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
(3,566 Views)
Thanks! that works.  Unfortunately I have to fix all of the ones on this.  Is there a faster way?
(3,552 Views)
It depends what is broken in the vi.
Andrew Alford
(3,545 Views)
