Configuring serial port advanced setting
Hey Guys,
I am working on one of the project where I need to access the PORT advanced setting programatically in LabVIEW.
But the serial APIs (VISA) in LabVIEW is application layer APIs.
Please help me with this.
(5,491 Views)
Use a property node Class= Serial:Instr  To read or write to the advanced properties of the I/O session.
That looks like any and all of the properties you can access on your JingSmiley Wink
(5,453 Views)
Jeff,
I am aware of all these properties.(BTW i dont see the buffer properties in the list)
My question was related to accessing the Low-high,receive transmit buffer given in windows property.
In labview class we can change these properties on application level but not on the physical port level.True?
Let me elaborate:
If I change (Jing) "Use FIFO buffer" in LabVIEW it will remain checked even if I change it in LabVIEW.
Please help me to find these properties directly instead of showing me an access to property of the port. 🙂
(5,447 Views)
Nothing easier  Mask selects recieve transmit or both
And yes.  you would need to use the Windows Registry functions to change the Windows settings from LabVIEW
(5,442 Views)
