Connect Amulet display to sbRIO
hi....is there any special RS232 port connector available for Amulet display?Display is having the j3 port but not connector.do i need to purchase it??
Message 11 of 16
(3,169 Views)
The Amulet display does not have a dedicated RS232 port.  You will need to use the J3 connector on the display to connect.  If you are using the RS232 connector on the sbRIO then the conenction to the display will be through J3 pins 13 & 18 (true RS232).  If connecting the display to the RMC connector on the sbRIO then you will need to use pins 7 & 8 on the display (UART).
Craig
Message 12 of 16
(3,161 Views)
Hi shilpawalia,
There are two options we have available to easily break out the serial communication and power from the Amulet connector. Here are the two options.
Power and communication cable - PN 157570-01
This is a single cable that connects to the amulet display on one end. The other end breaks out into USB (for power) and a DB9 connector (for RS232 communication).
Amulet RS232 and Power Interface Board - PN 783306-01 (http://sine.ni.com/nips/cds/view/p/lang/en/nid/212317)
The interface board mates directly to the Amulet display and has specific connectors for power and Serial.
Best,
Eric
Message 13 of 16
(3,147 Views)
Is there any connector available of sbrio 9636 for RS232 connector. coz the amulet display having DB9 connector on the other end but Sbrio dont have the RS232 DB9 connector.
Message 14 of 16
(2,876 Views)
Hi shipawalia,
As Eric-M mentioned in a previous post, you can use the Amulet interface board 783306-1 (http://sine.ni.com/nips/cds/view/p/lang/en/nid/212317) to connect the sbRIO to the Amulet.
Craig
Message 15 of 16
(2,869 Views)
The 10-pin IDC serial or CAN headers on the sbRIO can be broken out to a standard DB9 with a ribbon cable.  Many electronics stores that support building a custom PC stock these cables (we have Fry's around here), or NI also offers them for sale.  You can see them here:
NI Single-Board RIO Accessories
http://sine.ni.com/nips/cds/view/p/lang/en/nid/210789
The PN is 153158-10 - NI Single-Board RIO CAN/Serial Cable
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
Message 16 of 16
(2,866 Views)
