10-22-2010 04:53 AM
Hello, I'm Steve, I'm new in LabVIEW but I've searched a lot of information before ask for help.
Solved! Go to Solution.
10-22-2010 09:53 PM
I think your best option would be to use the dll that comes with the board. Don't know where you think you think you need to use C++ and the vendor should prove the .h file.
10-25-2010 03:37 AM
Hi Esteban,
I agree with Dennis, nevertheless, I'm not quite sure you need the *.h file. It may help tou understand the input/output parameters of ecah function, but a reference manual would be more helpful.
10-26-2010 09:42 AM
01-21-2022 08:19 AM
Hi Esteve,
just found your old post. Since I am looking for a .h file to import the DLL for a K8061 into Labview maybe you can help me out. Google was not helpful and vendor says product discontinued....
Thanks in advance
Werner
01-22-2022 08:49 AM
Wow, I didn't even remember this! I wonder how did you found this topic, must have been at the bottom of the whole internet!
All joking aside, I think I found my project but in your case I'd check the official website since it probably has updated drivers:
https://www.velleman.eu/support/downloads/?code=K8061
Attached to this message you will find the drivers and documentation related to Velleman K8061 and some tests in LabView (2009)
I didn't work with LabView anymore after that so I don't remember how I made it work, but I hope the files attached can help you.
Regards
Esteve
08-08-2022 06:27 AM - edited 08-08-2022 06:28 AM
Hi Werner,
Any chance with controlling the K8061 from Labview? Could you find some documented procedure?
Best,
Sébastien
