Connect servercontroller SC-610 from Harmonic Drive via serial bus as GPIB
Hello I upgraded a computer system from Windows XP to Windows 7 and from LabVIEW 7.1 to LabVIEW 2014. With my VI I'm comunicating with a Harmonic Drive SC-610 servo controller (RS232 connection on my serial port COM3) which controlls a Harmonic drive motion drive. Also there is a Faulhaber Motion drive connected on another serial port (COM4).
In the old system both ports where usable as GPIB but not so in my new system. There I get the error message Error connecting with the GPIB device or driver when I want to start my VI. NI VISA and 488.2 are installed. Also MintMT, MintWorkBench and Faulhaber Motion Drive are installed.
Is there anything I need to consider when moving from LabVIEW 7.1 to LabVIEW 2014 to fix this problem? How can I install the GPIB?
Best Regards
(4,306 Views)
which versions of the drivers are you using?
It is important that you choose ones, that are supported for LabVIEW 2014 e.g.
LabVIEW and NI-488.2 Version Compatibility - National Instruments
http://digital.ni.com/public.nsf/allkb/2BFCEE471BECB95F862574020059117E
(Be aware that the drivers should be installed after the LabVIEW development environment.)
I am a bit confused, do you want to control your devices using a serial port (then use the NI VISA functions) or via GPIB communication?
Cheers
Kathrin
(4,234 Views)
I recognized that there are no supported drivers on Windows 7 or with LabVIEW 2014 for AT-GPIB/TNT. But I installed the NI-488.2 Version 15.0bwhich is supported by LabVIEW 2014.
Thats the thing I didn't really understand either. It wasn't me who made the VI with its many Sub-VIs. I can't find out where the GPIB communictaion took place or where it is needed. In my opinion there is no necessary for GPIB communictaion but I can't find out where in the Vi it is used so I can handle it.
NI VISA functions should be enough. Is it possible to find out where it is used?
Greetings
Robin
(4,160 Views)
