Connecting Arduino to an CRIO
How can I connect an Arduino to a CRIO?
Serial Communication via the RS232 Port?
Is it possible to connect just the TX and RX?
Is there another option?
Are there solutions using different CRIO modules?
(5,868 Views)
I don't see how this has anything to do with Instrument Control.
I suggest you go on over to http://forum.arduino.cc
(5,863 Views)
I suppose you could use a DIO module to set up some weird specially communications.  But just using the serial port is by far the simplest method.  It is just VISA calls on the RT side and there are a ton of Arduino libraries for serial communications.
(5,860 Views)
http://forum.arduino.cc/index.php?topic=323926.0
I do think the problem is on the arduino side but nevertheless. Mabye you have an idea.
(5,837 Views)
