Connecting Superlogics ADC-1 I/O Module with third-party VI
I'm having trouble using the LabView driver for the ADC-1. It gives me the error "Resource not found" when I run the VI "ADC-1 Main.vi".
(3,238 Views)
It sounds like you are giving the driver the wrong VISA resource string. Make sure that the string is correct and try again. You should be able to check this in MAX.
Hope this helps out!
Best Regards,
Aaron K.
Application Engineer
(3,238 Views)
