Connecting to RXD and TXD pins
I have to connect a stepper motor having RS-485 interface to my PCI-8433/2 board. The motor has a DB-9 connector with two data pins marked "RS485A (+)" and "RS485B (-)".
Other pins are used for the power supply (2 pins), for connecting sensors (3 pins) and for relays (2 pins).
In the DB-9 pin description provided in the "NISerial.chm" file, there are four pins marked RXD+, RXD-, TXD+ AND TXD-.
Question 1: to which pins on the PCI-8433/2 board do I have to connect the two data pins of my stepper motor ?
Question 2: do I have to make also other connections, like pin 1 of the PCI-8433/2 to the GND pin used for supplying power for the motor ?
(13,831 Views)
Connect the RDX(+) to the TXD(+), connect RDX(-) to TXD(-).  If a terminating resistor is required, it shorts out these two lines.  Some specify 200 ohm for this, but I use 500 ohm due to my product limitations. In the computer device manager you will also need to select a 2 wire mode.  I use 2 wire auto.
RS485/RS422 and RS232 have a lot in common.  I am currently using NI 4 port 485/422 cards to talk both 2 wire RS485 and RS232 serial by using resistors in the connector.  The language and voltage levels are in practice the same.
(13,815 Views)
I would assume that the communication with the device is going to be one way (from the computer to the stepper motor) so I would recommend connecting the RS485A (+) and RS485B (-) pins to pins 8 and 9 which are the TXD+ and TXD- lines.  It may not be required, but connecting the GND pin of the stepper motor to the GND pin (which is pin 1) is probably a good idea.
Hope this helps!
Andy F.
(13,808 Views)
Two wire RS485 is bidirectional, but not at the same time.  It is called simplex (as opposed to duplex).  It is also multi-drop, in that multiple devices can be connected to these two wires.  Software handshaking handles transmit/receive as well as addressing control.  USB (universal Serial Bus) does the same thing.  The way this is done is by using high impedence tri-state devices for both transmit and receive.  Self test is easier, because the device talks to itself on the same wires--and there is one of the problems--software (or hardware) must mask out  transmissions with a delay or some other means.
(13,797 Views)
Thank you very much, I will try this solution.
(13,783 Views)
First thanks were for Andy.
Thanks to you also mhead, I will try also your solution
(13,782 Views)
