I would like to control my galvano scanner (ThorLabs GVS012) using BNC2120. Because it need some electonic connection between the device. I want to know what is the connection should be used to enable to control the galvano scanner by Labview using BNC2120.
FYI - the connection that need to be connect to GVS012 is pin J7 as manual attached (pg17), Im using NX
ril
