Connection to RS232
Hello @all,
i'll connect my µC with the RS232. To check the connection, i have a connect.vi. In this vi, i'll send the letter "D". The µC returns "D", if it was okay. And now there is my problem. How can i check, which letter i get. If it's "D" than i will get a true and it's any other letter or what ever i need a false.
For better understanding here is the vi.
But in this vi, i get only a false, if i get an empty string.
Thank you, all...
By Thomas
(3,869 Views)
If you want to see what the connection is returning, just wire the VISA Read to your string indicator. I don't understand why you have two different indicators - one for the true case and one for the false. Use a single one outside the case statement. Use Format Into String or Concatanate String to add your message to the read result.
(3,846 Views)
the two indicators are the problem. But the vi requires the a true-indicator and a false-indicator. But i can't specify the false-indicator, because of an error, i don't know what i receive.
if i receive "D" -> string-output--->connection o.k.
receive any other kinds of string or no string-----> string output----> connection failed.
Do you know what i mean?
Thanxs Thomas
(3,841 Views)
No, I don't understand why you need two indicators. Can't you simply do like the attached?
(3,833 Views)
Hi Dennis,
thanks for your help, thats it what i need.
Cu Thomas
(3,820 Views)
