Contolling USB port in the PC
I have a setup with a USB device. The USB device has a driver supplied with device. So when I plug the device into PC, the driver automatically detects the device and identifies it as a COM port in the PC. I need to test this device by disconnecting the device from PC. I planned to do this by disabling the device or uninstall the device as in the hardware manager option in windows. Is it possible for me to do this using labview?
The test is basically to simulate the connection and the disconnection of the device to the PC. Is there any way to perform this test?
Regards
Gopal
(4,365 Views)
Hi Gopal,
I have looked into ways to use a LabVIEW function to call an uninstaller, but Windows functions such as this are not accessible directly from LabVIEW.  Basically, if you are looking for a simple function in LabVIEW that can uninstall and reinstall the driver directly, it cannot be done.  The only approach I can recommend is to create a script that does this and call it in LabVIEW using a Call Library Function Node.
Hopefully this helps you out a little, but do not hesitate to contact National Instruments or post with further questions and/or clarifications.
Lauren L.
Applications Engineering
(4,342 Views)
Thank you for the information. I would also want to know whether the +5VDC from the USB port of PC be enabled and disabled?
Regards
Gopal
(4,316 Views)
Hi Gopal,
Since applications do not specifically communicate with the port itself, rather the device connected to the port, it is hard to programmatically disable a USB port.  Outside of LabVIEW, you can do this by disabling the port in the BIOS of your computer or by using the Registry Editor as explained at this link.
If you can disable the port outside of LabVIEW, you may be able to create a program that can call a script to perform the same function.  Unfortunately, we do not currently have a way to do this easily.
Lauren L.
(4,262 Views)
