Control DC power supply via RS232 interface labview
Hi everyone!
I am new to labview and I am trying to control a dc power supply by using an RS-232 interface (set the output voltage). I can't use a GBIP interface as I only have one module which is used for a different task. Any advice on how to go about this in labview?
Thanks a lot!
Message 1 of 9
(8,037 Views)
please specify which power supply, maybe a driver already exists.
And I don't understand your last sentence about only one module, so not being able to use gpib?
greetings from the Netherlands
Message 2 of 9
(8,035 Views)
I am using a TSX 1820P Programable DC PSU and I need to set the voltage via a RS232 module.
In my last sentence I wanted to say that I can't use GBIP as I don't have any available so I'd rather use RS232. When I searched online I only found solutions for GBIP, not RS232. Not sure how to use RS232 in labview unfortunately.
Thanks for all the help you can provide!
Message 3 of 9
(8,032 Views)
Accepted by topic author simm01
Find the driver for your device here: http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=510F94BB50256F51E0440003BA7CCD...
It will work for either GPIB or serial thanks to VISA.
Message 4 of 9
(8,013 Views)
Hi crossrulz!
Thanks for the driver. I tried to install it before and it wasn't working, it keeps giving me this error:
Error -1073807298 occurred at VISA Read in TENMA 72-685X.lvlib:Special Write-Read.vi->TENMA 72-685X.lvlib:Initialize.vi->TENMA 72-685X Output DC Volts.vi
No other program is having control over the serial port so I'm not sure why it isn't working. This is why I decided to create a topic on this website, thinking that that driver is only for GBIP because it wasn't working for me.
Many thanks!!
Message 5 of 9
(8,001 Views)
If your computer has a RS232 port , fine 🙂
if not:
-look up the main board datasheet, most of them have one but it's not connected to the outside (get a slot connector)
-use a USB to RS232 adapter
If not already done: Install the VISA driver (start MAX and have a look)
search the device driver database : in LabVIEW : Help - Find instruments driver...
if not found :
RTFM of the powersupply to get the protocoll details
Start with a simple example, Help - Find examples ... - HArdware ...  - serial -  BASIC SERIAL WRITE READ
If you have more detailed question provide type/model information and a link to the manual...
EDIT:   DAMN NEW LAYOUT    ...   😄
Greetings from Germany
Henrik
LV since v3.1
Message 6 of 9
(7,998 Views)
The description of that error states an IO error.  Are you using a USB-Serial adapter?  Are you sure your serial port actually works?  You should be able to test it using a terminal program like HyperTerminal or Putty.
Message 7 of 9
(7,988 Views)
Thanks  crossrulz!
Turns out the power source wasn't reading the commands sent from the PC, so it was a hardware problem rather than software. Everything works perfectly now, Thanks!!
Message 8 of 9
(7,959 Views)
Hey simm01,
I know that this post was a while ago but I seem to be having the exact same problem you did! I am using the same device and can write commands to it fine using VISA but when trying to read from it I get the I/O error. Would you mind letting me know how exactly you solved it?
Message 9 of 9
(6,249 Views)
