Control a pump via CompactRio
Hello
I would like to control a metering pump with a CompactRio. The pump asks for 4mA to 20mA to be controled. I have the NI 9381 module but it seems to provide only +-1mA. Does a module, which can control my pump, exist ?
Thank you
Marianne
(3,434 Views)
Hi MVDG,
Can you provide more details on exactly what your pump needs to be controlled?
Jiwhan S.
Technical Support Engineer
(3,404 Views)
Hello
Attached, you will find the data sheet of the pump
Thank you
(3,392 Views)
Accepted by topic author MDVG
Check out some of our Current Output modules in the link below:
C Series Current Output Module
https://www.ni.com/en-us/shop/model/ni-9265.html
Something like the 9265 can give the 20mA
NI 9265 Datasheet - National Instruments
https://www.ni.com/docs/en-US/bundle/ni-9265-specs/page/specs.html
Jiwhan S.
(3,382 Views)
Thank you very much !
(3,352 Views)
